Rounded Coffe Table
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/7752728/feed.jpg?1685087795)
![](https://d2t1xqejof9utc.cloudfront.net/pictures/files/229386/small.jpg?1637321793)
Making a Large Coffe Table Using (Fusion 360 , ART CAM ) , And fabricate it USing CNC Machine (Router)
Step 1: Design Using Fusion 360
First Thing You should do is to open Fusion to Start Designing
after You opend fusion go to FX icon and press on it to manage to make paramatric Design
After that you need to desigh a head of the table like i made here (don't Worry I will leave the Designs Down below)
Then I will Extrude the Shape like this (Extrude it as your Thikness of material)
Then Draw on the side view the Leg of the Table like this
And as the previous step ypu need to Extrude it
Then join all the Shapes together
And now we can say we are finished the first Step
Step 2: ART CAM
After you saved the Files you should open Art CAM that you should already installed and Prepare the Files on it (Tool Path , The End mill Thekness , Speed)
Step 3: Machinig
First Put the Wood on the Table of the Router and hold it with nails
then Put the G-Code (that you Export it from Art cam) Into the Controller Like That
Then Opearate the Router and Let it Do the Work (don't forget to choose the proper tool)
You will have Nice clean cut like this
I will leave Video to the Machine
Step 4: Assembling
After we finished from Cutting the wood
Now we will go to Assemble Process, Most of work will be in sanding the wood and give it nice texture
You Can Download All the files That I used by the following Link
https://drive.google.com/drive/folders/12MkeERZi8d1xAynAg1IXW50LuFigOxHC?usp=sharing
