Surface thicken problems in Solidworks
I think that there is a simple solution which you can try. just Un - tick the " Merge result" box and, retry your thickening procedure.
Best regards
Click the relevant surface which you want to Thicken, and go to the surface Tab, and click the Thick box. And then Un tick the " Merge result" box and, retry your thickening procedure.
