Tutorial - 2D Truss analysis in Mechanical APDL (ANSYS) Part 2?
In general, a finite element solution may be broken into the following three stages.
1. Preprocessing: defining the problem;
- Define keypoints/lines/areas/volumes
- Define element type and material/geometric properties
- Mesh lines/areas/volumes as required
2. Solution: assigning loads, constraints and solving;
3. Postprocessing:
- Lists of nodal displacements
- Element forces and moments
- Deflection plots
- Stress contour diagrams
In this tutorial we will go through second and third step.
    This is the second part of tutorials in Which we solve the problem. Under Solution >> Analaysis Type >> New analysis. Select static and click OK.
    Under Define Loads >> Apply >> Structural >> Displacement >> On keypoints. We will now define the fixed keypoints or supports.
    Select the two lower corner keypoints and click OK.
    Select All DOF and click OK.
  5. Step 5:
    Goto Define loads >> Apply >> Structural >> Force/Moment >> On Keypoints.
  6. Step 6:
    Select the upper keypoints and click OK.
  7. Step 7:
    Direction of force be FY and input Force value = -10000 since the force will be acting downward.
  8. Step 8:
    Now we have the model prepared for solution. Under Solve >> Current Load step.
  9. Step 9:
    Click OK.
  10. Step 10:
    A message Solution is done! will show when the process is completed. Click Close.
  11. Step 11:
    Now the third part of this process. Post-Processing is to be done. Goto General PostProc >> List Results >> Reaction Solu.
  12. Step 12:
    Select all items and click OK.
  13. Step 13:
    Now we have the value of reaction about the node 1 and 5 which are fixed. Click Close.
  14. Step 14:
    Goto Plot Results >> Deformed shape.
  15. Step 15:
    Select Def + undeformed. Click OK
  16. Step 16:
    Now we have the deformation plot.
  17. Step 17:
    Goto Plot results >> Contour plot >> Nodal Solu.
  18. Step 18:
    Under Stress select von Mises stress and click OK.
  19. Step 19:
    We have von Mises stress plot.
