Tutorial - Creating isometric circle (Front view) in AutoCAD?
Small
Here is the tutorial.
    Start AutoCAD.
    Use line tool and input these values=
    (0,0),
    @10<270,
    c.
    Now draw lines to the mid-points of the the lines.
    Draw these lines.
  5. Step 5:
    Use circle tool and then select this intersection as center.
  6. Step 6:
    Select the end point of the line.
  7. Step 7:
    Again circle tool and select the intersection.
  8. Step 8:
    To the end point of the line.
  9. Step 9:
    Select circle tool and select the corner.
  10. Step 10:
    To the mid-point of the upper line.
  11. Step 11:
    Again circle tool and end-point.
  12. Step 12:
    To the other end-point.
  13. Step 13:
    Trim tool and select all.
  14. Step 14:
    Trim away the components leaving the circles to arcs.
  15. Step 15:
    Delete all construction and we have circle.
Please log in to add comments
