Tutorial - Creating knurl in SolidWorks?
Here is the tutorial.
Start SolidWorks in Part mode.
Top Plane>>Sketch.
Draw a circle of 70mm diameter.
Extrude it by 100mm.
Select chamfer tool.
Select both edge and chamfer it by 5mm at 45º.
Select the bottom face and then sketch.
Select the outer edge and then convert entity.
Select Helix and spiral under curves.
Change defined by to height and revolution. Enter 100mm height and 0.25 revolutions at 0º start angle. Click OK.
Step 11:
Top plane>>Sketch.
Step 12:
Select Polygon tool.
Step 13:
Enter number of sides 3 and draw it along piercing the helix. Exit the sketch.
Step 14:
Under features tab select swept cut.
Step 15:
Select the triangle as the profile and helix as the path.
Step 16:
Now reference geometry and then axis.
Step 17:
Select Top plane and origin as the references.
Step 18:
Now select circular pattern.
Step 19:
Select the axis as the parameter and the swept-cut as the feature to be patterned. Click OK.
Step 20:
Select mirror tool.
Step 21:
About Right plane or front plane mirror the circular pattern.
Step 22:
Click OK.
Step 23:
And we have the Knurl obtained.
