Tutorial : Creating Rack and Pinion Motion in CATIA
Small
Here is how Rack and Pinion Mechanism can be created in CATIA
    Open Create_Rack2.CATProduct document.
    Click the Rack Joint icon in the Kinematics Joints toolbar or select Insert -> New Joint ->Rack... from the Menu bar.
    Select Prismatic.2 in the specification tree.
    Select Revolute.1 in the specification tree.
  5. Step 5:
    Assign a command, for instance select Angle driven for revolute check box.
  6. Step 6:
    Click Ok to end the rack joint creation.The rack joint is created and identified in the specification tree.
    Your mechanism can be simulated, a message is displayed.
  7. Step 7:
    Double-click Mechanism.1 to launch the simulation with commands functionality.
  8. Step 8:
    let's modify the ratio.
    Double-click Rack.3 in the specification tree
  9. Step 9:
    Click the Define button.
    The Rack Ratio Definition dialog box appears:
  10. Step 10:
    Select a circle in the geometry area. The ratio is automatically calculated.
  11. Step 11:
  12. Step 12:
    Click ok. Your Mechanism can be simulated.
Please log in to add comments
