Tutorial - Designing ATV tyre in SolidWorks?
Here is the Tutorial.
Start SolidWorks in Part mode.
On right plane sketch this profile.
Exit the sketch. Now under feature tab >> reference geometry >> axis.
Select front plane and origin.
Now revolve the profile along the axis.
Reference geometry>>plane>>top plane by 140mm.
On plane1 sketch the XX using the text tool. Change the font size to make it a little larger and adjust the settings of the text. If needed use a center line as a curve for text.
Under features tab choose extrude. Choose extrude type Up to surface and select the surface of the tyre. Uncheck the merge result.
Under surfaces choose offset surface.
Select the tyre surface. Remember if we have merged the XX body in the tyre than this surface would have been trimmed. Click OK.
Step 11:
Under surfaces tab choose cut with surface and select the offset surface and select the selected body>> uncheck the autoselect and select the XX body.
Step 12:
Click OK and we have the cut performed. Now hide the offset surface.
Step 13:
Now Select the circular pattern.
Step 14:
Select the axis and the XX body to be patterned and no. of instances be 20.
Step 15:
Click OK and we have the first half of the tyre.
Step 16:
Select the Mirror in features tab and select the front plane and then select all the XX bodies to be mirrored.
Step 17:
Click OK. Now goto Insert >>features>> combine.
Step 18:
Operation type - add. And Select all bodies to combine.
Step 19:
Click OK and we are done. Though this is not as good as last one i made.
