Tutorial - Freeform feature in SolidWorks?
Here is the tutorial.
    Start Solidworks in Part Mode.
    On front plane draw a arc with center at origin and radius 20mm.
    Under Surfaces tab choose extruded surface and extrude it by 60mm.
    Now go to Insert>>Features>>Freeform.
  5. Step 5:
    Select the extruded surface for freeform feature.
  6. Step 6:
    Click Add curves.
  7. Step 7:
    Add a curve.
  8. Step 8:
    Now click add points.
  9. Step 9:
    Add a point in between the curve.
  10. Step 10:
    Again click the add point and it will get embossed.
  11. Step 11:
    Now select the control point added and drag it to form a freeform feature.
  12. Step 12:
    After done click OK and then go to surfaces>>thicken.
  13. Step 13:
    Thicken it by 2mm.
  14. Step 14:
    Click OK and you are done.
Please log in to add comments
