Tutorial: How to check dimensions and derive ?
This is my entery to Tip and trics challange
Hello :) so
1) we have to have an assembley
2) open it
3) choose "inspect" (1)
4) analyze interference (2)
1) click at "analyze interference" (1)
2) define first solid/assembley (2)
3 )click on 1st assembley/solid in model enviroment (3)
Define second solid/assembley
2) click on 2nd assembley/solid in model enviroment (2)
3) then hit ok (3)
Now we can see where the solid/assembleys are intersecting each other
1) hit ok (1)
Now save your assembley
1) click on "Inventor" button (1)
2) click on "save as" (2)
3) click on "save copy as" (3)
Now create a new .ipt
1) hit "inventor" button (1)
2) choose "standart .ipt" (2)
3) hit create (3)
In new part
1) select "manage" (1)
2) hit "derive" icon (2)
Select copy of your assembley we created and then
1) Select red "-" next to every part (1)
2) Then select the only one we want to create to yeallow "+" (2)
3) Hit ok (3)
Now we can see our part derived so there will not be any colisions for 100%.
But check for error which this procced can create and remove them with standart tools.
Good luck with proceed and be carefull about the results.Thank u for reading and you can ask me any question :)
