Tutorial: How to create 3D contact with PTC Creo Parametric
Here is the short tutorial; How to create 3D contact with PTC Creo Parametric
Create Newton's Cradle assembly
Do not forget use the Pin constraint for main parts
Select Application > Mechanism > 3D Contacts
Select Surfaces for 3D contact (two spherical surfaces - for Newton's Cradle or one planar and second spherical - for Carambol's shots)
Select contact Tab and set custom material for 3D contact - check necessary Properties (Poissin's ratio, young's modul and Damping)
Note: try to manipulate with Damping value - you will see different final results
Try to manipulate with assembly parts and create custom animation
... note: for animation of Carambol's shots - use the 6DOF constraints (for all balls)
