Tutorial: how to create car rims in Solidworks?
Small
Tutorial - how to make rim
please don't forget to click on ''it worked'' :)
    Open a sketch and draw a rim profile like this
    Draw an axis and use revolve command
    This is the outer part of the your rim
    Sectioning. use selection view button
  5. Step 5:
    Draw rims internal part profile
  6. Step 6:
    Again use the revolve command. and be sure that ''marge result need to be unticked
  7. Step 7:
    Open a sketch on front plane and draw the profile that will be cutted. This is the most important step to create your own design wheels
  8. Step 8:
    Use circular pattern command and make your selection according to how many arms you want to do your rim
  9. Step 9:
    Edit your sketch with using trim command and cut the body. to cut only revolve2 you must select it on marked area
  10. Step 10:
    Use fillet command and fillet your bodies
  11. Step 11:
    Drill the rim for screws
  12. Step 12:
    use your creativity
  13. Step 13:
    And renders :)) plese click on it worked button if you liked this tutorial:))
Please log in to add comments
  • Missing feed
    Rosu Mihai
    we need dimensions!!!
    June 7th, 2018 09:51
  • Feed
  • Feed
    Mauricio
    Saludos, las dimensiones puede dar.
    November 18th, 2016 14:24
