Tutorial : How to edit STL file imported into SolidWorks
Small
Tutorial : How to editing files in SolidWorks STL file imported into
    Step 1
    Select the STL file> then select options
    Step 2
    Solid body in the select options> select> ok> open. finish
    Step 3
    This STL file before and after in options
    Bye ...
Please log in to add comments
  • Missing feed
    STI2D ITEC
    I dont get the "options" setting when I go choose the STL part, to Import it to solidworks... is it because I have windows 10 or?...
    Is there any other way to convert the part?
    January 31st, 2018 20:34
  • Missing feed
    aybike pirol
    OK I did it.My file type seemed to be "all files". I've corrected and I did "stl" .
    December 26th, 2017 11:42
  • Missing feed
    aybike pirol
    Hello, I wanted to try what you said here.But I did not see the 'options' option. There is only a reference option.
    December 26th, 2017 11:19
  • Missing feed
    prince das
    BUT CAN WE EDIT PART
    December 27th, 2016 06:38
