Tutorial how to make bearing
open a sketch on right plane began to drawing a sketch like this
use mirror command and trim command. draw the axis
use revolved boss command
open sketc to right plane and draw a circle. enter values
use revolve command again
use circular pattern command
open a sketch to righ plane and draw shown sketch
use revolve command. be carreful at volues
use circular pattern command again
connect the bodies which you created last
Step 11:
use mirror comand. that's all :))
