Tutorial how to make engine part 18
Small
Carter 3
    open a sketch on this surface
    use cut extrude command
    draw shown on the blue surface
    please examine the shown sketch. draw the same. then exit from sketch
  5. Step 5:
    click on the sketch from feature tree and click on show button
  6. Step 6:
    extrude this rectangles up to pink surface
  7. Step 7:
    open a sketch on this surface..
  8. Step 8:
    use section view command
  9. Step 9:
    draw shown sketch
  10. Step 10:
    add a circle
  11. Step 11:
    use trim command
  12. Step 12:
    extrude the sketch 4mm. make untick 'merge result' option
Please log in to add comments
