Tutorial how to make engine part 3
crank
open a sketch on the right plane and draw a sketch like shown
open a sketch on the body. draw a 30mm radiused circle and extrude it 20mm
use revolve command
go to other side draw shown sketch and extrude it 20 mm
open a sketch on same surface and draw shown skecth
use cut extrude command and tick 'filp side to cut'
now use mirror command. your crank began to take shape
use move copy body command. enter volues
rotate this (4th from right side) body 60degree
rotate 3th body 120 degree
Step 11:
rotate sixth body 180 degree
Step 12:
rotate second body 240 degree
Step 13:
rotate 5th body 300 degree
Step 14:
use combine command. your crank is ready for now. we will add oil canal and other parts after
