Tutorial how to make engine part 5
Small
Crank oil canal
    rollback the feature tree up to mirror1
    use 3D sketch and draw a line. starting point and endpoint have to be center of the circles
    delete the relations
    enter z coordinate -5
  5. Step 5:
    enter z coordinate 20 for this point
  6. Step 6:
    add a plane ( referance geometry>plane then select line and endpoint)
  7. Step 7:
    draw shown circle on this plane
  8. Step 8:
    use cut extrude command
  9. Step 9:
    open a sketch on shown surface and draw a circle
  10. Step 10:
    use cut exturde command
  11. Step 11:
    now open a sketch on the green surface, draw a circle and use cut extrude command
  12. Step 12:
    open a sketch on the right plane and draw shown sketch. then use cut extrude command and cut the body
  13. Step 13:
    roll forward the feature tree and open a sketch on the right plane
  14. Step 14:
    draw shown sketch then use cut extrude command
  15. Step 15:
    use fillet command
  16. Step 16:
    crank is ready now
Please log in to add comments
