Tutorial how to make nuts
tutorial: how to make nuts
open a sketch to front plane draw a circle and a hexagon then extrude it
open a ketch on the body and draw a small and bigger circle.
use cut extrude command and select the area between circles
click on draft and enter draft angle 60
mirror the cut extrude
open a sketch to front plane and draw a sketch like this. it will be tooth profile
now we will add helis. open a sketch top of body and draw a circle
use insert>>curve>>helis command and select circle and enter values
use cut swept command. select the tooth profile and select the helis
open a sketch to front plane and draw a thing like this. then use revolved boss command
Step 11:
your perfect nut is ready. Enjoy:))
