tutorial : how to render using keyshot
how to render
1 : open the file you want to render
2 : choose the file and press open
3: choose your oriëntation and press ok
4 : open library and choose the material what fits with your design
than drag the material to the surface you want to paint/ give a texture
5 : when you double-click on a surface,you get a window where you can change the settings, the settings are for every material different
- surface color is the main color of the surface
- subsurface is the color of the shine on the surface
- translucency is how good you can see through a surface
- with roughness you can change the shining, how higher,how less shine
6 : when you open the library again,and than open Environments/backplates or textures, you can choose the background for your rendering. To choose a background simply double-click on it
When you choose a good background,your rendering will be more realistic
7 : when you click render at the botom,you get a window where you can choose the options for your rendering, than press rendering in the window
8 : than wait untill your rendering is done, when you chose an high quality for your rendering,you must wait longer
DONE!!!!
