Tutorial - Indent feature in SolidWorks?
The indent feature creates an offset pocket or protrusion feature on a target body that exactly matches the contour of a selected tool body, using thickness and clearance values to create the feature.
    Start Solidworks in Part Mode.
    Front Plane>>Sketch.
    Make a profile like this one.
    Revolve it.
  5. Step 5:
    Now we have a revolved body.
  6. Step 6:
    In Features tab>>Reference geometry>>plane.
  7. Step 7:
    Choose Top Plane and keep the distance default 10mm.
  8. Step 8:
    Now we have a plane created.
  9. Step 9:
    Choose Plane1>>sketch.
  10. Step 10:
    Normal to View.
  11. Step 11:
    Make a circle of 30mm dia at 50mm distance.
  12. Step 12:
    Extrude it by 40mm and uncheck the merge result.
  13. Step 13:
    Choose OK. Now we have multibody part.
  14. Step 14:
    Choose Insert>>Feature>>Indent.
  15. Step 15:
    Choose the Revolve1 as target body.
  16. Step 16:
    Choose the Boss-extrude1 as the tool body region.
  17. Step 17:
    Check the cut option.
  18. Step 18:
    Choose OK. We can see in tree view that Indent feature is created.
  19. Step 19:
    Choose Boss-extrude1 and hide it.
  20. Step 20:
    We can see that an indented cut has been created for the tool.
Please log in to add comments
  • Feed
    Carlos Soler
    Good tutorial !!!, clear and precise, as must be
    September 1st, 2017 23:07
