Tutorial - Lofted Surface in AutoCAD?
Here is the Tutorial.
Start AutoCAD.
Choose Circle.
Enter center of circle as 0,0,0 and radius be 20mm.
Again draw a circle at center 0,0,20.
Input the radius value be 40.
Choose the front view from the navigation wheel.
Now the front view of the drawing is shown. If necessary regenerate the model using regen command.
Create two splines at the end points of the projected lines by the circles and a line along the y axis between the centers of the circles.
Under surfaces tab choose loft.
Select the upper circle.
Step 11:
Now select the lower circle.
Step 12:
Right click and Select enter or press enter.
Step 13:
Now Select Guides. And select the first spline.
Step 14:
Select the other spline also.
Step 15:
Right click the drawing and select enter or just press enter key.
Step 16:
Lofted surface is generated.
Step 17:
Choose isometric view from the navigation wheel and change the shademode to Conceptual for a better view.
