Tutorial - Modeling center block (universal joint) in SolidWorks?
Small
Here is the tutorial.
    Front Plane>>Sketch.
    Draw two circles of dia 56mm and 32mm.
    Extrude it in both directions. Towards front direction the distance be 28mm and towards back direction the distance be 82mm.
    Select top plane and then reference geometry >> plane.
  5. Step 5:
    Offset it by 28mm in downwards.
  6. Step 6:
    Plane1>>Sketch.
  7. Step 7:
    Draw a circle of 56mm dia. The circle is tangent to three edges.
  8. Step 8:
    Extrude it by 110mm.
  9. Step 9:
    Top face>>Sketch.
  10. Step 10:
    Draw a circle of 32mm dia.
  11. Step 11:
    Extrude cut it by Through all.
  12. Step 12:
    Select the back face>>Sketch.
  13. Step 13:
    Select the inner edge and then click Convert entities.
  14. Step 14:
    Extrude cut by thorugh all.
  15. Step 15:
    And we have the part body.
Please log in to add comments
