Tutorial - Modeling Crank Shaft in SolidWorks?
This is tutorial on making crank shaft. The main problem with making such design is with reading the dimensions on the drawing sheet. Well i have solved it for you. In this tutorial we will go through simple extrusion operation to make crank shaft.
Right Plane>>Sketch.
Draw a circle of 120mm and 4 holes of 12mm at 42.5mm from origin.
Extrude it by 16mm.
Right face>>Sketch.
Draw a circle of 50mm dia.
Extrude it by 40mm.
Right face>>Sketch.
Draw this profile.
Extrude it by 22mm.
Right face>>Sketch.
Step 11:
Draw a circle of45mm at 40mm from origin.
Step 12:
Extrude it by 35mm.
Step 13:
Right face>>Sketch.
Step 14:
Draw this profile.
Step 15:
Extrude it by 25mm.
Step 16:
Right face>>Sketch.
Step 17:
Draw a circle of 45mm dia.
Step 18:
Extrude it by 35mm.
Step 19:
Right face>>Sketch.
Step 20:
Draw this profile.
Step 21:
Extrude it by 22mm.
Step 22:
Right face>>Sketch.
Step 23:
Draw a circle of 45mm.
Step 24:
Extrude it by 45mm.
Step 25:
Right face>>Sketch.
Step 26:
Select this face and click Convert entities since the profile is same.
Step 27:
Extrude it by 22mm.
Step 28:
Right face>>Sketch.
Step 29:
Convert the circular edge.
Step 30:
Extrude it by 35mm.
Step 31:
Right face>>Sketch.
Step 32:
Convert this face since the profile is same.
Step 33:
Extrude it by 25mm.
Step 34:
Right face>>Sketch.
Step 35:
Convert the cirular edge from 4th extrusion.
Step 36:
Extrude it by 35mm.
Step 37:
Right face>>Sketch.
Step 38:
Select the 3rd extrusion face and convert entities.
Step 39:
Extrude it by 22mm.
Step 40:
Right face>>Sketch.
Step 41:
Step 42:
Extrude it by 145mm.
Step 43:
Right face>>Sketch.
Step 44:
Draw a rectangle of this dimension with one point coincident on the circular edge at a distance of 4.5mm.
Step 45:
Extrude cut it by 100mm.
Step 46:
Right face>>Sketch.
Step 47:
Draw a circle of 28mm.
Step 48:
Extrude it by 28mm.
Step 49:
We have the crank shaft.
