Tutorial - Modeling Spring in AutoCAD using extrude face?
Here is the tutorial.
Start AutoCAD.
Draw a circle.
Draw a line bisecting the circle in half.
Select trim tool. Select all.
Trim the lower half.
Erase the line. Now use mirror command and select the circle.
Mirror it along the arc end points.
Use viewpoint command and enter 1,-1,1 or choose SE Isometric under view menu.
Rotate3d and then select the half circle.
Select Y-axis.
Step 11:
Select the end point of the arc and rotate it by 5º.
Step 12:
Repeat the same step for the other half.
Step 13:
Rotate it by -5º.
Step 14:
Copy command and then select both arc.
Step 15:
Multiple type copy. Select the lower end point as the base point.
Step 16:
Selct the upper point as target point.
Step 17:
Repeat the same step and we have helix.
Step 18:
Change the UCS about X at 90º.
Step 19:
Draw a circle at the end point of the helix.
Step 20:
Extrude command and then select the circle.
Step 21:
Right click and then select path.
Step 22:
Select the helix arc as the path and the part of the spring is generated.
Step 23:
Modify>>Solids Editing>>Extrude faces.
Step 24:
Select the face of the helix.
Step 25:
Right click and then path.
Step 26:
Select the arc.
Step 27:
Repeat the same step for the rest of the helix part and the spring is generated.
