Tutorial on " How to create spring in Solidworks"
This tutorial explains " How to create spring in Solidworks".
For video tutorial kindly click on following link
Step 1: Go through the diagram
Step 2: Draw a circle for spring
Select a right plane and draw a circle of diameter 60mm
Then exit from sketch
Step 3: Drawing helix
Select the circle and go to curves-> helix and spiral
As the pitch and height is given, select "pitch and height from drop down list"
Enter height as 97, pitch 9.7 and starting angle as 180 degree
Step 4: Now will draw remaining sketches
Select front plane and draw sketch as shown in figure
Step 5: Add new sketch
Now we have to join the helix and the last drawn sketch. To joining, we have to use 3d sketch.
Select spline from draw toolbar
Join two endpoints using spline
To maintain the proper shape, we have to adjust both control point. Select first control point and click on "along x"
Similarly select second point and click on "along y" in add relations
and exit from sketch.
Step 6: Draw sketch on other sides
Draw a sketch on front plane as shown in figure
Step 7: Join sketch and helix
Again repeat step 5
Step 8: Join all the sketches
Now we have to join all the sketches to make smooth path
Go to Curves-> Composite curve
Select all the sketches and click ok
Step 9: Creation of solid for spring
Go to sweep
Click on circular profile option as our profile is circular
Select path and set diameter as 9mm and click ok
Step 10: Final product
The spring will look like this
Step 11: Video tutorial
For video tutorial click on my video
