Tutorial on Modeling Bolt in SolidEdge ST4?
Small
Tutorial.
    Start SolidEdge.
    Circle tool and then select origin.
    Make a circle of 20mm diameter on top plane by locking it clicking on the lock icon.
    Select Extrude.
  5. Step 5:
    Select the circle and then right click.
  6. Step 6:
    Extrude by 100.
  7. Step 7:
    Polygon tool.
  8. Step 8:
    Top face and then select the center of the edge.
  9. Step 9:
    Distance be 16.5mm and angle 0.
  10. Step 10:
    Select the region of the polygon.
  11. Step 11:
    While pressing the control key on the keyboard select the region on the circular face also.
  12. Step 12:
    Extrude it by 12.5mm.
  13. Step 13:
    Select chamfer equal setbacks.
  14. Step 14:
    Lower edge and input value 5.
  15. Step 15:
    Front view (Control key + F).
  16. Step 16:
    Draw a line along Z-axis of 85mm with endpoint at origin.
  17. Step 17:
    Polygon by Center.
  18. Step 18:
    Click the intersection of these two edges.
  19. Step 19:
    Input Distance 1mm.
  20. Step 20:
    Select helix under cut features.
  21. Step 21:
    Select the line.
  22. Step 22:
    Select the polygon.
  23. Step 23:
    Click Tick mark button.
  24. Step 24:
    Input turns 22.5mm. Right click to accept it.
  25. Step 25:
    Now go to the end face of the thread. Select the face and then project the edges.
  26. Step 26:
    Extrude it by remove at ~10mm.
  27. Step 27:
    Our bolt is ready.
Please log in to add comments
