Tutorial - Press-pull tool in AutoCAD 2011?
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/29274/feed.jpg?1552114776)
Here is the tutorial.
Start AutoCAD.
Draw a closed profile using line tool.
Under solid tab select press pull or enter PRESSPULL in command manager.
Click inside the region bounded.
Now assign the height.
Now draw a circle at mid point of the edge.
Again select press pull and extrude it downward. Since there is already material therefore it will remove material.
