Tutorial - Rebuilding curve in AutoCAD?
Here is the tutorial
Start AutoCAD.
Make a spline using SplineCV feature in Surfaces tab.
When you have made the spline select it and then select the rebuild option.
The rebuild curve screen pops up.
Change the degree to 5.
Click OK and the spline is rebuilt with the continuity.
