Tutorial - Spine feature in Creo Elements aka Pro/E?
Here is the tutorial.
Sketch >> Top plane.
Draw a semi-circle.
Extrude it as surface.
Change the view from planar using mouse middle button.
Right click and hold it. Then select references.
Select the end points on top plane as reference.
Also select the other point too.
Sketch orientation.
Spline tool.
Step 11:
Draw a spline by using vertex references.
Step 12:
Exit the sketch.
Step 13:
Insert >> Warp.
Step 14:
Select the quilt as the body to deform.
Step 15:
Click Spine tool.
Step 16:
Select the spline as the chain.
Step 17:
Type to warp radially from center.
Step 18:
Now deform the quilt using the control points.
Step 19:
Click OK and the feature is generated.
