Tutorial - Twist feature in Creo Elements aka Pro Engineer?
Here is the tutorial.
Sketch >> Top plane.
Draw a polygon by using profiles.
Exit the sketch. Extrude.
Extrude the polygon.
Insert >> Warp.
Select the geometry body and change direction to top plane.
Click Twist tool.
Input the angle value and click OK.
The feature is generated.
