Tutorial - Using blocks in AutoCAD?
Tutorial by Sudhir Gill
Small
Here is the tutorial.
    Start AutoCAD.
    Draw a profile using pline. Click Make block icon.
    Type the name of block BLOCK. Click Select objects.
    Select the object.
  5. Step 5:
    Change the units to Millimetre.
  6. Step 6:
    Click pick points.
  7. Step 7:
    Select the base point.
  8. Step 8:
    Click OK.
  9. Step 9:
    Click Insert block.
  10. Step 10:
    Select the block and click ok.
  11. Step 11:
    Select the location of the base point.
  12. Step 12:
    Similarily insert the blocks.
Please log in to add comments
