Tutorial - Using design table in SolidWorks?
Small
Here is the Tutorial
    Start SolidWorks in part mode.
    Top plane>>sketch and draw a rectangle.
    Extrude it.
    View>>Dimension names.
  5. Step 5:
    Select the dimension and in left pane change the dimension name to lenght.
  6. Step 6:
    Repeat the same step for other dimension.
  7. Step 7:
    Insert>>Table>>design table.
  8. Step 8:
    change setting to Blank, Block Model edit, and uncheck all the option. Click OK.
  9. Step 9:
    Now excel worksheet will appear. As you click the dimension in model they are automatically added in worksheet.
  10. Step 10:
    Now add other instances like i added in datasheet.
  11. Step 11:
    Exit excel worksheet by clicking the workspace. Goto Configuration in Property manager.
  12. Step 12:
    Double click the grey coloured instances.
  13. Step 13:
    And here we have the different configuration for one part.
  14. Step 14:
    As we select the part we see that all dimensions are pink in color which means they are dependent on design table and configuration.
Please log in to add comments
