Wall Bracket With Pedestal Bearing
A pillow block bearing (or Plummer block) is a pedestal used to provide support for a rotating shaft with the help of compatible bearings & various accessories. The assembly consists of a mounting block that houses a bearing. ... Housing material for a pillow block is typically made of cast iron or cast steel.
Step 1: Components
Step 2: Assembly
Step 3: Properties
