What may cause this problem while rendering with Photoview 360?
Here is the Solution.
    I have a spark plug part in SolidWorks.
    When I render it, half of the body is inside the floor.
    Now I close the render window and click Edit scene.
    Change align Floor with to XZ plane which I assume is the floor.
  5. Step 5:
    Now i change the view to front view.
  6. Step 6:
    I drag the double arrow to downward which is the floor offset.
  7. Step 7:
    The floor is aligned with this arrow. Since this is below the model now, the floor will be just below the model.
  8. Step 8:
    I click OK and then final render.
  9. Step 9:
    Now the render is good and the floor is also OK.
Please log in to add comments
  • Feed
  • Feed
    Rade Dzinkic
    Thank you man!
    Someday I will buy you a drink!
    July 21st, 2017 10:02
