I tried to generate the tutorials long enough for everyone to understand and enough short to won't be boring. please click on it worked buttons, so I can know how many users following the tutorials
CYLINDER HEADS
Step 1
open a sketch on this surface
Step 2
draw a circle (2,5mm radiused)
Step 3
use cut extrude command
Step 4
make same things for the other side
Step 5
use mirror command and select the right plane for mirror face
Step 6
click on the shown surfaces
Step 7
open a sketch on the shown surface
Step 8
draw shown sketch
Step 9
use extrude command like shown
Step 10
open a sketch on the same surface
Step 11
draw shown sketch
Step 12
use extrude command again
Step 13
Step 14
draw a circle
Step 15
draw two centerline for mirroring
Step 16
use mirror command
Step 17
use mirror command again
Step 18
extrude it by 50mm
Step 19
Step 20
draw four circles
Step 21
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-32
