Tutorial: How to make engine part 31
Small
CYLINDER HEADS
    open a sketch on this surface
    draw a circle (2,5mm radiused)
    use cut extrude command
    make same things for the other side
  5. Step 5:
    use mirror command and select the right plane for mirror face
  6. Step 6:
    click on the shown surfaces
  7. Step 7:
    open a sketch on the shown surface
  8. Step 8:
    draw shown sketch
  9. Step 9:
    use extrude command like shown
  10. Step 10:
    open a sketch on the same surface
  11. Step 11:
    draw shown sketch
  12. Step 12:
    use extrude command again
  13. Step 13:
  14. Step 14:
    draw a circle
  15. Step 15:
    draw two centerline for mirroring
  16. Step 16:
    use mirror command
  17. Step 17:
    use mirror command again
  18. Step 18:
    extrude it by 50mm
  19. Step 19:
  20. Step 20:
    draw four circles
  21. Step 21:
    next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-32
Please log in to add comments
