CyDesign Part 2: Cummins VT-903-M Engine
Given simply an image of the engine, can you produce a detailed surface model? If so, cash in on your skills.
CyDesign is launching 6 challenges, each with a different engine or transmission that needs 3D CAD files generated for modeling. Each of the 6 challenges has a $500 prize for the best model. Win all 6 challenges and you could have $3,000 very quickly!
CyDesign is populating a small library of engines and transmissions used in the modeling of vehicles and vehicle capabilities. Currently, they have a few pictures and 2D graphics of these select engines and transmissions, but need to have 3D CAD models for each engine and each transmission. Each challenge centers around modeling specific engine or transmission.
No internal surfaces or components are required- only external surfaces need to be modeled and then rendered.
While images are provided for a starting point, these might not have as much detail as desired.
A simple Google search can pull up additional pictures, images and specifications as needed.
THIS CHALLENGE CENTERS AROUND MODELING THE CUMMINS VT-903-M ENGINE.
Requirements
  • 3D CAD models submitted should be similar in fidelity to those shown in these already created GrabCAD solutions: diesel engine and diesel engine
  • Models can be done in any CAD software, need to have STEP/.stp files uploaded as final submittal. 3D Studio Max compatible files are also acceptable if you are unable to produce .stp files
  • The 3D CAD models only require external surfaces modeled and rendered; no internal surfaces/components needed/required. The final uploaded .stp file only needs to be have the assembled model without the constituent parts
  • Mono-chromatic coloring with minimal shading required; do not need complex, multi-light source shading
  • 3D CAD models require one axis of rotation
  • Uploading CAD files of rendered models without permission to your GrabCAD profile is not allowed
  • The submissions will be judged on realism, creativity and composition
Rules
  • The competition is open to everyone
  • Team entries are welcome. In case of team win, prize money will be transferred to team leader who is solely responsible for splitting it among team members
  • You may submit multiple entries
  • Tag your rendering with “CUMMINS” when uploading it to GrabCAD
  • All 3DCAD files have to be public
  • Only models uploaded to GrabCAD library will participate in the competition
  • Only models uploaded through this challenge page here will participate in the competition
  • Entries to be submitted as .stp files
    .3ds files also acceptable
  • This competition ends 8/17/12
Prizes
$500 for most realistic 3D CAD of the model provided
About the jury?
Submissions will be judged upon timeliness of submittal, accuracy of 3D models relative
to picture(s)/diagrams/images provided and file size of final CAD file (smaller is better).
The judges will be comprised of CyDesign and GrabCAD staff.
About CyDesign Labs
CyDesign is developing a physics-based modeling system that will let the engineer quickly assess design options against requirements during the conceptual design stage.
Should the vehicle have conventional or hybrid drive? How will thermal loads affect an implanted medical device? By providing answers to these questions early in the design, a more robust and reliable system will be built.
CyDesign Studio will help the engineer manage key requirements, keep them pertinent to the design, explore the trade space of possible design alternatives, assess the viability of these alternatives, and provide guidance resulting in a much better final product.
http://cydesign.com/
25 comments
  • Ian Cummings
    Ian Cummings about 13 years ago
    Will you provide overall dimensions like last competition?
    Ian Cummings has uploaded 5 CAD models & has left 4 comments.
  • Kyle B
    Kyle B about 13 years ago
    Difficult challenge without dimensions... the end result won't really be of much use if its not accurate...
    Kyle B has uploaded 9 CAD models & has left 17 comments.
  • JF Brandon
    JF Brandon about 13 years ago
    @Kyle Bateman It is completely possible to do - there are dimensions out there on Google.
    JF Brandon has uploaded 10 CAD models & has left 341 comments.
  • Alan Baird
    Alan Baird about 13 years ago
    Hi guys the VT903 engine size,,,,,,,,, as follows Length 65,40in (1662.5 mm)
    Width 38.43 in (976mm) and Height 37.81 in (960mm)
    Good Luck
    Alan Baird has uploaded 107 CAD models & has left 115 comments.
  • David Hinz
    David Hinz about 13 years ago
    Kyle, JF, Alan and others,
    yes, i have been challenged to find better images and specs as well.
    that is why included the specific part name, as others may have
    better luck than i do (which happened on the detroit engine challenge!)
    do your best on this challenge in the short time frame!
    thanks for the great support and interest.
    David
    David Hinz has uploaded 2 CAD models & has left 95 comments.
  • David Hinz
    All,
    Remember, do not need internal components/pieces in final model or rendering for this challenge; only need external surfaces modeled and rendered.
    Thanks
    David
  • EDISON PHOENIX
    EDISON PHOENIX about 13 years ago
    When will the five Cy-Design Challenges end (the deadline- in time zone)?
    EDISON PHOENIX has uploaded 141 CAD models & has left 682 comments.
  • Kaspar Kiis
    Kaspar Kiis about 13 years ago
    Challenge will end in 22 hours.
    Kaspar Kiis has uploaded 3 CAD models & has left 635 comments.
  • David Hinz
    Deadline is per Pacific Time zone (US, California time)
  • Farzin Raafat
    Farzin Raafat about 13 years ago
    hi kaspar,the same problem happend again,i uploaded my files and redering for cummins contest 3 hours before endtime,it uploaded to my page and library,but it is still not in entry list of the contest.please help.
    Farzin Raafat has uploaded 23 CAD models & has left 134 comments.
  • Amin Ghedmat
    Amin Ghedmat about 13 years ago
    Hi there!
    I've the same problem as farzin's...There is steel time to submit my model but after i submit it,nothing appears in entries list!
    Amin Ghedmat has uploaded 12 CAD models & has left 52 comments.
  • Cemal Uslu
    Cemal Uslu about 13 years ago
    here i have the same problem. Cummins VT-903-M Engine
    Cemal Uslu has uploaded 44 CAD models & has left 321 comments.
  • Alan Baird
    Hi Guys
    I have the same problem the model is on site, and it was uploaded to the challenge page, I can only assume that there is an issue with the update on the challenge page. So I am sure your entries will all be accepted
  • Cemal Uslu
    that always happens! if you uploaded before the deadline and didn't edit it after the deadline there won't be any problem. good luck ;)
  • Amin Ghedmat
    I think there is a problem with Grab Cad's upload server!
    because from 3 hours before dead line till now i have a problem with uploading any file to my library...
    I hope owners of this challenge count this unexpected error and give us a second chance...
  • Kaspar Kiis
    Hi everybody, we will not miss off any of the entries. Just have another look at http://grabcad.com/challenges/cydesign-part-2-cummins-vt-903-m-engine/entries and send me an e-mail directly to kaspar@grabcad.com if your entry is not listed. Thanks.
  • EDISON PHOENIX
    When will be the result announced..???
  • Abhijeet
    Abhijeet about 13 years ago
    Congratulations to all the winners !
    Abhijeet has uploaded 98 CAD models & has left 428 comments.
  • Kaspar Kiis
    Congratulations to all the winners! I have to admit that I was bit skeptic about the challenge before we launched it. The quality of the pictures weren't too good and the expected level of complexity extremely high. Moreover, it all was needed within 7 days.
    I have to take my hat off for all of you. You completely blew me away with your entries. Thank you all! It is great to be part of this powerful community!
  • Alan Baird
    Congratulation Farzin and all the other winners
  • EDISON PHOENIX
    Congratulation Farzin & all the winners...!!!
  • David Hinz
    Thanks to everyone for participating in CyDesign's GrabCAD challenge.
    We continue to be amazed at the high level of quality, accuracy and completeness provided by each entry; this community is awesome! We appreciate everyone's time and effort, as all the entries were very good indeed.
    We look forward to working with this community in other challenges soon.
  • mohammadreza.k
    mohammadreza.k about 13 years ago
    Congrats dear Farzin, I knew you're the best.
    mohammadreza.k has uploaded 1 CAD models & has left 7 comments.
  • Farzin Raafat
    thank u mohammadreza
