Catia Macro Export Points to Excel (get coordinates from a local axis system)
Hi there,
I'm using a nice Catia Macro in order to get points coordinates to an excel File. This macro gets the coordinates from the absolute axis system. Now I need to get these coordinates from a different axis system. Any idea/tip how can I do it?
Please find below the code I've been using:
Dim objGEXCELapp As Object
Dim objGEXCELwkBks As Object
Dim objGEXCELwkBk As Object
Dim objGEXCELwkShs As Object
Dim objGEXCELSh As Object
Dim FS, f, f1, fc, s
Dim coords(2) As Variant
Dim partDocument1
Sub CATMain()
CATIA.ActiveDocument.Selection.Search "CATGmoSearch.Point,all"
StartEXCEL
ExportPoint
End Sub
Sub StartEXCEL()
Err.Clear
On Error Resume Next
Set objGEXCELapp = GetObject(, "EXCEL.Application")
If Err.Number <> 0 Then
Err.Clear
Set objGEXCELapp = CreateObject("EXCEL.Application")
End If
objGEXCELapp.Application.Visible = True
Set objGEXCELwkBks = objGEXCELapp.Application.WorkBooks
Set objGEXCELwkBk = objGEXCELwkBks.Add
Set objGEXCELwkShs = objGEXCELwkBk.Worksheets(1)
Set objGEXCELSh = objGEXCELwkBk.Sheets(1)
objGEXCELSh.Cells(1, "A") = "Name"
objGEXCELSh.Cells(1, "B") = "X"
objGEXCELSh.Cells(1, "C") = "Y"
objGEXCELSh.Cells(1, "D") = "Z"
End Sub
Sub ExportPoint()
For i = 1 To CATIA.ActiveDocument.Selection.Count
Set Selection = CATIA.ActiveDocument.Selection
Set Element = Selection.Item(i)
Set Point = Element.Value
'Write PointData to Excel Sheet
Point.GetCoordinates (coords)
objGEXCELSh.Cells(i + 1, "A") = Point.Name
objGEXCELSh.Cells(i + 1, "B") = coords(0)
objGEXCELSh.Cells(i + 1, "C") = coords(1)
objGEXCELSh.Cells(i + 1, "D") = coords(2)
Next
End Sub
Thank you in advance!
Pedro
I would run the macro as-is to put the points relative to the Absolute Axis System, and then I would use an Axis-to-Axis Transformation to move the points to the local axis system.
