how to fix the POSITION of a component and not the mates between components..
i got stuck with this during assembly of suspension system..pls help
If you want to fix the components in space in what ever potion they are right now, then you can use lock mate.
select mates-> lock-> then select the components and select the assembly origin.
Try distance mates between the planes in the assembly and faces or planes in the parts.
