hi,Is it possible to install 64 bit CATIA to install on 32 bit processor system? please support
while installing it is showing error.
64 bit software is all about memory access. They are geared toward using more than 4 Gigs of memory, but 32 bit processors max out at 4Gigs. Even if you could trick it into installing you would crash every time you tried to use more than 4Gigs, which is not under your control.
