Is there any way to use Solidworks 2010 64 bit to run Solidworks 2011 32 bit files?
I heard that Solidworks 2010 cant run Solidworks 2011 files. But is there any way to make it happen?
No, SolidWorks is not backwards compatible.Once a file has been saved in SolidWorks 2011, it cannot be opened in SolidWorks 2010 unless it is exported as a neutral file (i.e. Parasolid). Note that when importing a neutral file all feature data history is NOT included.
The only way is to save the 2011 files out as a parasolid prefered (STEP,IGES) and import them into 2010.
