Hole Wizard Sizing Help
What should I put in the hole wizard for a 1/4-20 UNC .500? I attached the Blueprint of the part I almost finished. I couldn't attached the part because of technical errors.
not quite sure what your after. do you want the tap depth to be 1/2" length?
