How can convert a solid volume that makes by Autodesk Inventor to PDMS Software? (Data Base Format)
2 Answer
Hello jwd
After a quick look in google! I found the following links they might be helpful.
http://support.aveva.com/services/products/30272/ug30272.pdf
http://www.egpet.net/vb/threads/15877-How-to-import-3d-models-to-PDMS
Also, I strongly believe without be familiar with this software that you should have the chance to save your (.ipt) file as (.dwg) or (.stp) or (.sat) in order to import it in the PDMS.
Good Luck
Let me know if that worked for you.
Best Regards
Ioannis
Dear Loannis
Thank you so much
It was Usefull
