How can I use Drive Constraint with two o more constraint?
Basically, my doubt is because I want to make a simulation with two movements.
If anyone can help me, I'll be grateful.
Regards
Regards
Omar if you put up a sketch then others will be able to help you as not being able to see what you want done does not help us.
:P
The simple answer is yes, you can drive more than one constraint if they can all be mathematically driven from one parameter. Drive the constraint with that parameter and all of the them will move.
If there is no mathematical connection, then i do not believe it is possible within Inventor.
