how to change default density value in pro e???
we normally used same material in the assembly . so i want to change the pro e default density value .......
I don't think it is possible in assembly; but you can modify material properties of a part.
Go to File--Properties--Assign material to your part--Change the units if you want--In front of Mass Properties you will find a 'i' symbol--click on that symbol and you will find a report generated.
In this report you can find density of a part.
