How to Fix a component in NX assembly
how to ground a component in nx assembly so that it won't move when i use move command. in solidworks just right click and select fix.
to used fix constrain.to fixed the compound
Try Assemblies-Assembly constraints. Type menu-fix or align/lock. A component can be fixed to a face, axis, edge... of another component.
Fix is used to ground the component or we can say that is used to fix that part in whole assembly.we can fix that by fix constrain which is in assembly>assembly constraint>fix
By this you can fix part.
You can do that by make that component totally zero constraints.
