How to restore dimensioning function
Hi everyone, I have a problem related to my autocad dimesnioning function. I have completed my sketch and begun to put some dimensions on it, after the moment I gave dimenssions for angles, it started to aknowledge measures under the color of construction instead of dimension. Since that it doesn't measure even straight lines. It is totally converted into green(construction layer) instead of blue(dimension layer).
Plus my construction layer was turned off, before I started using dimensions.
Right click on screen .. choose options then click profile and reset ..
