how to simulate a roller with different material.
I need to simulate a roller with number of materials for Static. Plain carbon steel , Oak ,etc(all are in the attached drawing). Both ends fixed to bearings. how can i simulate this.
you could configure it ... where your feature manager tree is there will be a tab that looks like a yellow box with a arrow or a dot its configureatoins .... click on the default till its blue then right click add configuration and they you can change the material type in that config and its the same part
