If we want to install Ansys software again in the system after properly not installing it, do we need to format the system and then need to install it again
I have installed Ansys software in the system but in the download file magnitude is removed as it contain virus, so the software did not installed. Again i am downloading to install it. My friend said I need to format the system, if it is not installed in the first
you need not to format the system first you check start> all programs> Ansys 13.0> status if it is even improperly installed there will be< uninstall> option if it is there you uninstall it and install again it will be ok while installing first run magnitude file-- it will ask for licence creation ... press --Y the symbol******* wlill be running and a new licence will be created then > run set up LM and it will ask for licence you have to select the licence created in magnitude then step by step install the Ansys software (note: better first install SetupLM then you run Setup)
