is it possible to know element size in solidworks flow simulation?
Hi. Im running a flow simulation using solidworks 2020 student edition. May i know if there is a way to know what the element size of the solid model? Or only in simulation we can know about it? I'm changing the refinement level to investigate the effect of element size for heat conduction in the solid model. Thank you
Accepted answer
0 Other answer
