Is there an easier way to make the angle lines of a protractor than making each line individually?
Do I have to make 90 lines individually for a 90-degree protractor or is there an easier way to do that?
Never mind, I figured it out.
I could make 1 line or a few lines and then use "Circular sketch pattern".
Select the angle that you want to cover and check "equal spacing".
Move your center point to where you want it and set your spacing.
